Pushrod info
Old Jan 8, 2016 | 09:08 PM
No false Bravada's Avatar
No false Bravada is on a distinguished road
Default Pushrod info
My Bravada came down with a case of the lifter tick. Sounds just like it did in my old Chevy Cheyenne with the 4.3 TBI. It's not rod knock (top or bottom) and it's not piston slap. This gives me an excuse to get new lifters, pushrods and rocker arms.
Here's my question. On Rockauto, they offer pushrods of two different lengths. One is 7.195" oal for intake and exhaust, and the other is 7.1870" oal, also for intake and exhaust. Would I be able to use either one?
I imagine there wouldn't be a huge difference, and I doubt the .008" would cause any interference.
Old Jan 13, 2016 | 08:30 AM
LesMyer's Avatar
0.008 will make no difference.
Does your lifter tick sound like this (post#1 video)?
https://blazerforum.com/forum/2nd-ge...g-valve-87514/
Posts 25 and 26 show the problem.
Old Jan 14, 2016 | 04:12 AM
It's nowhere near that loud. Mine has no problem with oil pressure. Cold start, it goes up to 60 psi and stays there until warm. After warmed up sufficiently, it goes down to no lower than ~45 psi idling, and will go up to 60 psi again when I accelerate.
Aside from the tick, mine is quiet.
Old Jan 14, 2016 | 06:05 AM
Toocute350's Avatar
Toocute350 is on a distinguished road
My oil pressure gauge fluctuates also.The gauges aren`t that great.Just as long as your oil light doesn`t go off your good.Diffentely sounds like you have a failed lifter.
Old Jan 14, 2016 | 06:24 AM
According to a former GM mechanic, as low as 18 psi can be acceptable. Mine never goes below 40-45 psi when warm, so that's not a problem. That seems even better than the MOT truck (management of traffic) that I drive at work. It's a 2006 International 4300 with the International 7.6L L6 turbo diesel. Cold start, it goes up to 60-65 psi. Warm, it settles to about 25-30. But diesel engines do operate a little bit differently than gasoline engines.
Old Jan 14, 2016 | 07:22 AM
LesMyer's Avatar
Good! Sounds different from mine. Also keep in mind that loose valve guides can tick as well.
Best wishes for a successful repair.
Old Jan 14, 2016 | 02:09 PM
Another thing I just thought of. I'll need to replace the uim/lim gaskets too. That'll knock those out of the way as well.
Old Jan 17, 2016 | 12:39 PM
The average Joe would say "man, I gotta buy parts and have work done? Crap!"
People like me (and there appears to be a few people just like me on this forum) say "I gotta buy parts and put them on? Maybe even buy a new tool or two? Yes!"
98moneypit
Jul 23, 2014 01:46 PM
2bejustme
Jan 27, 2013 06:27 PM
benthm7
Jun 16, 2011 09:07 AM
Grkblazer
Tires and Wheels
Sep 4, 2005 02:54 PM
Scooter
Apr 20, 2005 12:44 AM
