Question where to make the cut.
Isnt it harder to remove the seats, center consul, and carpet than removing the Y pipe? I know the Y pipe is a little bit of a pain to remove but i think easier than cutting. Or you can cut the Y pipe out and do Duals early lol.
But if you are dead set on cutting a hole, look at (if you can) where the the lines are in relation to the shifter. Unless yours in on the column? In that case Take a drill bit and drill a hole in the floor where you think the lines are and use a flashlight to look at how close you are. Its a lot easier to plug a drill bit hole if you guessed wrong.
What Im going to is get a look on the underside,I`ll make a line up into the inside drill a hole an go from there.Mean while I need to get another set of ramps one of mine got crushed.
Well today I was able to look underneith my Jimmy and dtermin where I will need to make a cut in the floorboard should I decide to pursue this route.
Now Im thinking of something different less destructive.Im probaly going to take it to a shop that i deal with and let him raise the vehicle high enough to do the work underneith it.
I realy dont feel like pulling up the carpet and undoing all the molding that holds it in place.Might cost more but at least it will be done the right way.
