Quick question about an engine swap....
Old Mar 6, 2009 | 07:54 PM
coltc's Avatar
coltc is an unknown quantity at this point
Default Quick question about an engine swap....
I'm sure it has been discussed but I can't seem to find it anywhere.
I have the chance to pick up a 4.3 motor out of a 95 AWD Astro Van. This will drop right into my 95 Blazer, correct?
I guess while I have you here, any pointers for doing this motor swap? This will be my first time changing a motor in something other than a motorcycle. Anything I should look out for?
Thanks.
Old Mar 6, 2009 | 08:49 PM
I believe this should be the same as your truck... I would have a look at the motor first to make sure that there were not differences in the intake.
Old Mar 7, 2009 | 01:56 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Supposedly it's a direct swap. You might need to check the oil pan and oil cooler line stuff and swap them over, though.
Old Apr 7, 2009 | 08:08 PM
coltc's Avatar
Thought I'd post a follow-up for this...
Here's a few things that were different. That I remember...
-Air intake plenum. (Van motor one didn't have the place to attach the brake vaccum line)
-Distributor (Van wasn't the enhanced distributor)
-Timing chain cover and pick-up under it. (because of the different distributors I had to swap the Blazer stuff onto the Van motor)
-Knock sensors and locations (they were different or at least one of them was I can't remember)
-Remote oil filter assembly (had to use the one off of the Blazer, Van didn't use a remote set-up)
-The coolant hose attachment at the thermostat (Different angle between the Van and Blazer)
-Motor Mounts
Old Apr 8, 2009 | 08:30 PM
Thanks for the follow up. I figured that some of the sensors and other bolt on things would be different.
The vans have a hydro-boost setup for the brake booster which uses pressure from the power steering pump to assist the brakes.
SureShooter29
Mar 18, 2010 03:02 PM
BeeLaser
Feb 25, 2010 01:46 PM
gmoney30
Jan 22, 2010 07:07 PM
Lilcheef
Oct 7, 2008 02:19 AM
blazinwoody
Engine & Internal
Jan 11, 2007 05:30 PM
