Rebuild in Future, Worth it?
Old Feb 17, 2009 | 10:50 PM
BlazinMike89's Avatar
BlazinMike89 is an unknown quantity at this point
Default Rebuild in Future, Worth it?
I am really leaning more towards a complete overhaul and cam swap in the next year. My question is, how good is a rebuild and is it worth it?
Old Feb 18, 2009 | 05:01 PM
Default RE: Rebuild in Future, Worth it?
That question really depends on the extent of the wear. If your motor is just getting tired, you may be fine with re-ringing it and throwing new bearings in. If it has significantly lost compression and/or spun a bearing, you may need to have the crank turned and the cylinders bored which will require a machine shop. When you build the motor back up after either of these, you will need to get the appropriately sized bearings for the crank and larger pistons/rings. When properly done, the engine will be like new again.
skid9832004
Jul 9, 2012 08:09 PM
BlazinMike89
Lifting Tech
Jan 25, 2009 04:17 AM
JerzeyLegend
Jan 3, 2009 01:33 AM
nj4x4blaze
Oct 17, 2007 06:19 PM
SuperRy
Lifting Tech
Jun 6, 2007 09:43 PM
