removing the oil pan
Old Nov 22, 2010 | 02:09 PM
rigdog's Avatar
rigdog is on a distinguished road
Default removing the oil pan
I'm tring to replace the oil pan gasket and was wondering if it would be easier to lower the diff opposed to raising the motor. I'm doing this in the
drive way and with very limited tools.Starting to get frustrated first exhaust then water pump and timing cover which turned into oil pan. I appreciate any and all input thanks..........
sorry i have a 1995 chevy s-10 blazer 4.3 4x4....
Last edited by swartlkk; Nov 22, 2010 at 02:39 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Nov 22, 2010 | 02:40 PM
*Moving to Engine & Internal* - Please read the descriptions of the forum sections and choose the appropriate section for your post. Technical questions belong in the technical sections. Thanks.
Old Nov 22, 2010 | 02:48 PM
rigdog's Avatar
I guess I'll just figure the **** out my self since I can't seem to get it in the right section and can't just ask a flippin question, it shouldn't matter what section your in either you know the answer or you don't reply thanks anyway>>>>>>>>>>
Old Nov 22, 2010 | 03:06 PM
I have a lot of things to do around here and one of those things is to keep this place orderly. Sorry you took offense to me moving your thread, but it is no reason to get all bent out of shape over it. In fact, that kind of attitude will not be tolerated on this forum nor would it result in getting you the help you seek.
If I still have time after I get done responding to the more courteous members of the forum, I will attempt to help you.
Old Nov 22, 2010 | 03:07 PM
m3ch's Avatar
m3ch is on a distinguished road
i wouldnt talk that way to an admin
and btw, use the search button and take time to wait for answers, no one will answer you if you talk like that
Old Nov 22, 2010 | 03:31 PM
robertr728's Avatar
robertr728 is on a distinguished road
Comment withdrawn. Never mind enjoy your repair.
Old Nov 22, 2010 | 03:42 PM
rigdog's Avatar
I appolagize!! Just got a little frustrated tring to get this done before it gets cold or rains and can't get it done and the only response I got was from admin telling me to go somewhere else. I'll be off the forum as soon as i'm done. I'm going to try to stretch it over the pan.. when i'm done i'll post it so others will know that it can or can't be done...If you never gottin frustrated working on a vehicle then you've never turned a wrench otherwise you'd be a LITTLE understanding I would think..agian I am sorry for the outburst..
Old Nov 22, 2010 | 04:00 PM
About your repair, like mentioned earlier, use the search feature. It has been discussed before. The method you take really depends on what you have available in terms of tools and experience. And since you haven't elaborated, I will not speculate.
Most everyone gets frustrated when working on things from time to time, especially when rushed. The difference here is that you let that frustration control you to the point where you spit on the very people you were asking to help. Not a good idea in any venue... No one here gets any compensation for the time used to help others. How would you feel if someone asked you for help with an attitude like you have displayed here?
The nature of your responses will determine how well you get received around here. By your first few attempts...
Old Nov 22, 2010 | 11:03 PM
rigdog's Avatar
well I have installed the oil pan gasket by streching it over the pan. There really wasn't much streching involved and was really pretty easy. Just make sure the pan is really clean and be gingerly with it and you shouldn't have much problem but that was my experience and i'm no mechanic just do what I have too..good luck to all..
Bluebeastblazer57
Aug 11, 2012 11:05 PM
rigdog
Nov 22, 2010 02:42 PM
dmc919
13
Mar 29, 2010 11:16 PM
bigwes
Jan 20, 2009 01:00 PM
dmndeacon
Jan 20, 2007 12:46 PM
