rough idle?
Old Oct 22, 2012 | 01:09 PM
Steve-o's Avatar
Steve-o will become famous soon enough
Default rough idle?
i just replaced my fuel filter and now my blazer idles rough. help please? 96 4wd 4dr
Old Oct 22, 2012 | 02:04 PM
Rottidog's Avatar
Did you install it backwards? Kink any lines? Possibly the grud that was in there got disturbed & made it to the fuel lines & to the poppit valves in the spider.
If it's ok then I'd do a fuel pressure leak down test. You can search that out in here for how to do it & the pressures needed.
Old Oct 22, 2012 | 05:39 PM
Steve-o's Avatar
well i desided to take it advanced auto and have them check all the codes thats on it. Was a MAF low frequency and a cyl 5 misfire. I fixed the misfire and runs perfect now. Odd that i showed up like this though o.O
any clue to what low frequency MAF means excatly?
Old Oct 22, 2012 | 05:42 PM
Rottidog's Avatar
Look up Cleaning MAF in here & try that. It's simple but a little delicate.
Old Oct 22, 2012 | 05:45 PM
chris015's Avatar
Stevo,just pop off the maf,go buy you some mass airflow cleaner (DO NOT USE ANYTHING ELSE) and spray the precious guts on the inside. Do not scrub. let dry. reinstall and try it out.
Old Oct 22, 2012 | 06:01 PM
Rottidog's Avatar
You can use denatured alchohol as well. Rubbing alchohol is the same thing & cue-tips. Do not use carb cleaner or throttle body cleaner (so I've heard)
I keep a bottle of rubbing alchohol in the blazer with cue-tips just for that because mine see's a lot more air passing through it than a naturally aspirated engine.
Pick it up at a pharmacy, wally world etc.
blazerguy22
Nov 14, 2013 11:50 PM
Chevrolet.Love
Aug 19, 2011 09:05 PM
nhguy261
Dec 30, 2010 01:41 PM
97BLAZE4X4
Feb 7, 2010 07:33 PM
c10jm
Aug 12, 2008 05:34 PM
