Runs but studders at low and high and have to turn over for 10 to 15 sec to start
Old Apr 11, 2017 | 01:58 PM
Brandon Barthel's Avatar
Brandon Barthel is on a distinguished road
Smile Runs but studders at low and high and have to turn over for 10 to 15 sec to start
I will try and start it but have to turn over for 15 sec or so and it will fire then when i take off it stutters until it shifts to 2nd gear and run fine. When i get to about 3 to 3.5 rpms it starts stuttering again got a different upper intake cover with all the electrical and valves (from salvage yard and took them all off and cleaned them except for the tuner valve). It ran perfectly for the ride home (7 miles) and started the samething again in the morning. New injecter spider and fuel pump and filter. New spark plugs and wires and cap were put on also. All done about 2 months ago. What to do?
Old Apr 12, 2017 | 07:30 PM
Strangerock's Avatar
Strangerock is on a distinguished road
Have you done the fuel system test to verify the fuel pump and regulator are not failing ?...Do you have access to a scanner that can do real time ?...a road test with such scanner may help pinpoint a problem.
dflanigan
Jan 3, 2014 06:06 PM
lifted99blazer
Mar 1, 2013 01:45 AM
IronMan
Sep 21, 2011 11:28 PM
j79302j
Aug 31, 2010 09:02 PM
greeneyes1975
Jul 11, 2010 02:37 PM
