seafoam
yea im prob gonna get the spray kind and try it that way. it might of been that clean bc i did an intake about 5 thousand miles ago and the intake was nasty with carbon all over it and i cleaned it all back to metal but i was sure there was more carbon everywhere but i dunno, it did make it run butter tho so i guess ill just leave it at that for now
i have a 1999 blazer 4.3vortec . i just put 4 ounces of seafoam in the oil crankcase. drove it around for 15 miles and noticed the idle is smoother i thought my engine was off it was so smooth. i checked the dipstick after and the oil didn't turn super dark yet. but we will see what color it turns after 100 miles then i will do a oil change. the reason why i tried this is because my oil pressure seems kind of higher than normal and the engine would give off a bad smoke smell under the hood when the engine is cold . maybe its my pcv valve . we will see if it goes away because i never had this problem before and the burning smell goes away when the oil pressure lowers a bit when the engine warms up. my theory is the engine is dirty inside or the pcv valve is not working correctly to vent the combustion gases inside the crankcase or valve covers. maybe someone can give me some advice
so i used it today and i didnt have the results everyone else has. i poured 1/3 in the tank and turned on my truck poured about 1/3 down the brake booster vac line and shut off the truck, waited 20 mins turned it back on and it didnt smoke at all. should i try using more in it? i hear your not suppose to have it stall out your truck. so idk, maybe its just that clean inside? but i doubt it cause it has 146k on it, so idk what i did wrong
