Selector thingys
Bear with me!
I've got a 2000 Blazer, which I'm having a few problems with. Unfortunately, here in the UK, garagesseem stumped when I ask for help with my Chevvy!
On the dash, I have buttons to select 4Wauto, 2wd, 4hi & 4lo. Recently, they have not selected correctly, mainly I'm in 2wd, but when I need to select another, it just flashes and returns to 2wd.
There isn't any noise when it hops back.
Not good when I'm towing out of a muddy field.
Can any of you help?
when i first got my blazer, it was doing the same thing. it would flash 3 or 4 times if you press 4HI then return back to 2HI. after changing the fuse on the inside fuse panel, it worked fine...
there seem to be a lot of people with 4wd problems and there are plenty of threads with a similar topic. if you use the search function at the top, you might find more solutions andrecieve more helpto find out what is wrong
SWATPARAMEDIC
Jan 1, 2010 03:12 PM
warriorcustoms
Apr 4, 2009 11:51 AM
myblackblazer
Jan 11, 2009 11:15 AM
Jetfixer
Dec 23, 2005 01:54 PM
