slow acceleration. gearing?
Old Jun 23, 2009 | 05:44 PM
motocrossism's Avatar
motocrossism is on a distinguished road
Default slow acceleration. gearing?
I just got a 91 S-10 Blazer 4x4 4.3 V6 the Blazer runs fine but is very slow to accelerate. Off road its a beast but in drive or overdrive it has NO power. The blazer has acted like this as long as I'm aware of. The vehicle has a new exhaust, fuel and air filters, and spark plugs. Would this be a gearing/transmission issue?
Also this Blazer has a automatic transmission.
motocrossism
Old Jun 23, 2009 | 06:52 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
what gears do you have in the rear now?
Old Jun 24, 2009 | 05:16 PM
Default more info
I don't know the ratios I have a owners manual unfortunatley its 2hrs away from me. The Blazer has 1, 2, 3, Drive and Overdrive.
both the tire size and gearing in the blazer are stock.
Like I said the Blazer has no power from a take off however after the RPM's get high enough it is much more responsive. On a take off the engine bogs down. However when off road when using lower gears the engine seems to not bog but break the tires loose.
My thoughts were the problem could be
gearing
governor
or the fuel injection
Old Jun 24, 2009 | 08:26 PM
AJBert's Avatar
Well, these vehicles are not beasts off the line to begin with...lol
How old are the cap, rotor and wires? Coil? Have you tried Seafoam? Injector cleaner? MAF clean? It could be a number of things.
Also, look in your glovebox, should be a lable with a bunch of codes. One of them should be GU and a number. That will be you axle ratio. Post up the GU code and we'll know what gears you've got.
Old Jun 25, 2009 | 12:24 AM
Blazercrazy's Avatar
Blazercrazy is an unknown quantity at this point
Go take a look in your glove box, You will either find a Gu4(3.08's) Gu5(3.42's) or Gu6 (3.73') on the code sheet, I had problem like this, I ended up sea foaming it and it gained some power back but never got down to the problem before it came the parts truck(Only because the core body was shot)
Old Dec 28, 2009 | 06:58 PM
92blazer92's Avatar
92blazer92 is on a distinguished road
My 92 is doing the same thing, did you ever fix the problem?
tdbone1
Dec 20, 2012 09:40 AM
chadd77
Oct 13, 2010 09:03 AM
matthew.chapman1
Aug 22, 2009 07:32 PM
Jimmysls98
Feb 28, 2007 10:40 PM
beeneeb
Feb 12, 2007 06:44 PM
