some sort of wiring probleam
Old Nov 19, 2009 | 03:45 PM
squire_jimmy's Avatar
squire_jimmy is on a distinguished road
Default some sort of wiring probleam
To start I have a 2.8 fuel injected 1987 s10 blazer. Now for some reason the fuel pump will not turn on when you turn the key ahead but the relay does seem to be working. Also if I unplug the relay and jump the two wires(the power wire and fuel pump wire the fuel pump kicks on and starts pumping gas so I know its not the fuel pump. What could it be?
Old Nov 19, 2009 | 04:09 PM
tazz9690's Avatar
tazz9690 is on a distinguished road
if you say the relay is good, but the pump doesn't turn on, so you jump the wires and the pump does turn on, then it's probably still the relay. just cuz it seems like it engages doesn't mean it actually did. or it could have, but the connection is bad because of the arcing. it could be several things. My suggestions is swap out the relay for another one to verify if the relay is actually bad or not.
Dobe Rottie Gang
Aug 30, 2013 11:14 AM
jonj238
Dec 29, 2011 07:47 PM
Blazer51
Nov 25, 2011 04:42 AM
modifyyy87
Nov 3, 2010 02:10 AM
dougg01
Lifting Tech
Jun 15, 2010 11:42 AM
