sort of DONE with lift on '00 Jimmy...
Old Mar 26, 2010 | 11:56 AM
dougg01's Avatar
dougg01 is on a distinguished road
Default sort of DONE with lift on '00 Jimmy...
T-bar crank and 1.5" shackles - minor trimming.
New shocks, ball joints, front CV shafts, exhaust (dynomax), sway bar bushings, etc.
No sway bar rub. Minor frame rub at full lock. Might just weld a tab on the stops to limit it a bit. Got a bit of fender rub at compression in a partial turn. We'll trim the wheelwell a bit more to clear that.
We'll plan a 2" body lift in the summer. I'll have to add some steps for the kids to get in and out though.
Next to a ZR2 on 31x10.50 BFGs in the parking lot at work....
Tell me what you think....
Old Mar 26, 2010 | 01:38 PM
nj4x4blaze's Avatar
Looks good.
Old Mar 26, 2010 | 03:00 PM
zedartwo's Avatar
Yea looks good. I'm Jealous your slightly higher than my ZR
Old Mar 26, 2010 | 03:18 PM
dougg01's Avatar
thanks guys.
For reference....
The driver's-side used 5 turns and the passenger side got 5.5 turns. Neither is maxed out, but the driver's-side has only a couple turns left till the threads are used up.
Alignment was a non-issue. Lined up perfectly with nothing special needing done.
I do want a steering stabilizer.
Old Jun 15, 2010 | 12:14 AM
GrnBstrd's Avatar
GrnBstrd is on a distinguished road
Hi dougg, I am the new proud owner of a 2000 Chevy Blazer and am also new to this forum. I am looking at doing a t-bar crank like you did. I have a few questions for you though!
My plan is a 1.5" T- Bar crank up front; and shackles in the rear; how ever I want the truck to sit level like yours pictured above. I am curious as to how much you adjusted yours? And by 1.5" shackle did you mean it lifted you 1.5", or is the shackle 1.5" longer than stock?
And if you know what is the relation between shackle length and actual rear lift achieved? I have heard multiple ratios from 80-50%? Since a level ride is what I'm going for any insight would be greatly appreciated!
BTW your jimmy is looking pretty sick! Love it!
Old Jun 15, 2010 | 06:29 AM
dougg01's Avatar
The shackles I used are from Warrior Products out in Oregon (I can't find the link right now). They have an ebay store. The shackles GIVE 1.5" of lift. I measured and they are roughly 2" longer than stock.
I cranked the front up right under 1.5". One side took 2 more turns that the other, but the bolts have plenty of threads left so they aren't maxxed out yet.
I still need to get longer shocks because I am shorting myself a little bit on full extension when I have the sway bars disconnected.
thanks for the compliments. If you look at my threads in the build section you'll see more pics of it and the work I did.
Good luck with yours.
Old Jun 15, 2010 | 11:42 AM
DKSDAD's Avatar
Hey Dougg01, what size tires are you running that you have rubbing issues?
Dobe Rottie Gang
Aug 30, 2013 11:14 AM
jonj238
Dec 29, 2011 07:47 PM
Blazer51
Nov 25, 2011 04:42 AM
modifyyy87
Nov 3, 2010 02:10 AM
squire_jimmy
Nov 19, 2009 04:09 PM
