spark plug won't stay tight
Old Nov 5, 2011 | 09:00 PM
xgiovannix12's Avatar
sounds good
Old Nov 5, 2011 | 09:26 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
If the head is stripped cant you put a Heli Coil in it? lots easier than getting a new head.
Edit: dont pay attention to what i just said, lol thats a bad idea. If it comes down to it which hopefully it wont, you can tap the head. You have to turn the motor over until the piston is level with the spark plug hole and with the exhaust valve open. then do the tapping procedure and after you are done vacuum it out with a small tube, then after that blow air in at about 100PSI to blow anything else out the exhaust. a few small pieces of metal is better in the cat than the rings. but like i said hopefully you wont have to do that.
Old Nov 5, 2011 | 09:29 PM
TheRandom1's Avatar
I've heard bad things about heli coils in the past. I may do that (if needed) as a temporary thing, but I wouldn't trust it as a permanent solution.
Old Nov 5, 2011 | 09:39 PM
oops lol didnt edit fast enough.
futuredoc
Oct 7, 2024 06:14 PM
4.3l trouble
Apr 7, 2019 06:54 PM
Yankee Team1020
23
Aug 3, 2011 08:05 AM
LORCLAS
Apr 17, 2007 09:44 AM
boulonman
Mar 5, 2007 05:10 AM
