Sputter and then fine
Old Jun 29, 2019 | 06:29 PM
Cubanliink's Avatar
Cubanliink is on a distinguished road
Default Sputter and then fine
Hi there, new to the group, but I was wondering if this has been an issue for any of you.
From a cold start, my 1998 Blazer 2W starts fine without fail. It idles perfectly fine in or out of gear. Once I start the vehicle and put it into gear, I lose power significantly to the point of bucking and slight back firing. I feather the throttle for 45 seconds or so and ta-da! Works just fine until I shut it off again for any period of time. Any help would be appreciated
Old Jul 14, 2019 | 12:29 PM
Cubanliink's Avatar
Default Update
So I went in to get the codes read and there were 3 of them: P0453, P0171, P0174. I knew the fuel filter and fuel pump were bad so I went ahead and replaced those and their respective wiring harnesses as they were pretty beat up. Cleared codes, and those 3 pop back up. Any help would be appreciated.
Old Jul 17, 2019 | 05:34 PM
Pat8987's Avatar
Pat8987 is on a distinguished road
Probably the spider injector
Search it up
Longer02
16
Jan 26, 2011 06:25 PM
wrencher73
Dec 27, 2010 08:35 PM
DINKERV
Jun 3, 2010 07:20 PM
terry s
Jun 29, 2009 11:15 PM
Jesse
Sep 28, 2008 06:17 AM
