Sputter when shifting
Old Mar 23, 2015 | 09:14 PM
Daryllee's Avatar
Daryllee is on a distinguished road
Default Sputter when shifting
I have a 96 Blazer that when its cold it sputters or hesitates when shifting. Mostly between 1st and 2nd. Acts as though its cutting out. When its warm its fine. Could it be a vacuum leak somewhere?
Old Mar 23, 2015 | 09:55 PM
Gambit66's Avatar
Gambit66 is on a distinguished road
Numerous reasons could cause this. Is your check engine light coming on? Does it have a steady idle? Vacuum leak would be present at idle usually.
Things to check, proper fuel pressure, clogged fuel/air filter, fuel electrical system, plugs, wires, uneven cylinder head pressure, ignition system, vacuum leaks at throttle body, intake, and brake booster line. as well as all vacumm lines.
Old Mar 25, 2015 | 04:59 PM
Daryllee's Avatar
Ive replaced some vacuum lines,next is plugs,wires,filters. It idles fine and goes down the road fine. Just shifting when cold it sputters. Thanks for the input and I'll see if I can narrow it down
Old Jan 28, 2020 | 04:23 PM
Allenk's Avatar
Allenk is on a distinguished road
Did you ever find out what was causing this issue. I'm having the same problem.
Old Jan 29, 2020 | 03:52 PM
A little old of a thread... not sure if op is still around...
edit: just checked to see, and hasn't been on since dec of 15....... so doubt there will be an answer... from op anyways...
Old Jan 2, 2021 | 09:43 AM
Michaelhill11's Avatar
Michaelhill11 is on a distinguished road
Default 2001 Chevy Blazer 4x4 morr sputters going from 1st gear to second gear also second
I have the same problem 2001 Chevy Blazer 4x4 motor sputters going from 1st to second also from 2nd to 3rd gear. We changed almost everything we seen everyone talks about this problem, anyone have any suggestions please you can even call me with suggestions please Mike 732-690-1811
rwomer
Mar 17, 2018 09:41 AM
brandywine050
Sep 29, 2011 11:54 AM
blazingtrails93
May 30, 2011 04:06 PM
blzn95
Jan 15, 2009 05:27 PM
martinblazer95
Jan 2, 2008 10:52 AM
