starter for voretec 350 doesnt engage my flexplate on 77 blazer
Old Jul 1, 2011 | 05:01 PM
burfdogg's Avatar
burfdogg is on a distinguished road
Default starter for voretec 350 doesnt engage my flexplate on 77 blazer
I have installed a 96 vortec 350 in my 77 blazer. When I did this I ended up using an older flexplate so that the button on the crank and the torque converter input shaft would both fit through the hole in the flexplate. I thought i counted teeth and checked everything for diamiter. but now when i go to get a starter from the store none of them even come close to touching the flexplates ring gear. can anyone tell me rthe correct dia. of the flexplate i should have and how many teeth it should have. any other details would likely help too. I was eating starters before and a friend of minw had a starter that worked but he doesnt have another and that one he hand filed to get proper clearance with the bendix and the ring gear. Duh dont I feel smart. thanks for yous alls time.
Old Jul 1, 2011 | 08:06 PM
rriddle3's Avatar
*Moved to 'Engine & Transmission'. The 'New Member' section is not for asking technical questions.*
Old Jul 2, 2011 | 08:30 AM
TZFBird's Avatar
TZFBird is on a distinguished road
A '96 350 should use a flexplate for the single piece rear main cranks. So the oldest it can be is somewhere in the mid '80s. At this time you should have a 153 tooth flexplate correct? What starter are you trying to use? They made 153 and 168 tooth flex plates I believe so if you are trying to use a starter for the '77 it may be for a 168 tooth which is something like almost 1" larger in diameter than the 153. That would result in the starter sitting about 1/2" out to far from the flexplate.
Old Jul 3, 2011 | 08:52 PM
burfdogg's Avatar
that is what i needed to know. Yes 1/2" or so from the bendix gear is the issue of the momenrt. will keep you informed thanks.
tech180
Feb 2, 2013 10:23 AM
lazer2000
Sep 16, 2012 11:16 PM
chris015
Nov 15, 2011 05:49 PM
hitechracing
Sep 1, 2009 11:52 AM
96blazerfun
Mar 22, 2009 07:50 PM
