still no reverse
after the tranny swap I still have no reverse. I am still using the old trasfer case. Fluid levels are ok. 2000 Blazer w 4L60E tranny. I'm confident that this newer tranny is fine as I bought it from a used parts dealer who sells to GM dealerships.
I believe I have a PCM problem - I disconnected the 13 pin connector on the rear right of the trans and then I had reverse temporarily. But after checking fluid levels and adding more fluid I still have no reverse with or without the 13 pin tranny connector plugged in.
What else could be causing this problem here?
Well apparently the real problem was lack of fluid - after reading the tutorial in theabove link and seeing that around 12 quarts of fluid would be required in all - I figured I would be absolutely certain I had enough fluid in the transmission. The dipstick read onlya little low on the hot end but I added another quart anyways. Now reverse and all gears seem towork fine again (even with the 13 pin connector plugged in).
I just didn't think the transmission would require that much fluid
Kurt Phillips
Mar 15, 2014 09:21 PM
vmx120
Sep 12, 2005 07:10 PM
