still no reverse
Old Aug 19, 2008 | 03:23 PM
2000Blazer4x4's Avatar
2000Blazer4x4 is an unknown quantity at this point
Default still no reverse
after the tranny swap I still have no reverse. I am still using the old trasfer case. Fluid levels are ok. 2000 Blazer w 4L60E tranny. I'm confident that this newer tranny is fine as I bought it from a used parts dealer who sells to GM dealerships.
I believe I have a PCM problem - I disconnected the 13 pin connector on the rear right of the trans and then I had reverse temporarily. But after checking fluid levels and adding more fluid I still have no reverse with or without the 13 pin tranny connector plugged in.
What else could be causing this problem here?
Old Aug 19, 2008 | 08:01 PM
WolfPack's Avatar
Default RE: still no reverse
Could be an issue with the valve body? Maybe one of the runners is clogged? Just throwing something out there though..I'm no tranny expert...
Speaking of which...wheres Hanr3..
Old Aug 20, 2008 | 09:38 AM
Well apparently the real problem was lack of fluid - after reading the tutorial in theabove link and seeing that around 12 quarts of fluid would be required in all - I figured I would be absolutely certain I had enough fluid in the transmission. The dipstick read onlya little low on the hot end but I added another quart anyways. Now reverse and all gears seem towork fine again (even with the 13 pin connector plugged in).
I just didn't think the transmission would require that much fluid
Old Aug 20, 2008 | 09:53 AM
A low fluid level can cause some really weird problems. Hopefully that was not the problem with the previous transmission as well...
Kurt Phillips
Mar 15, 2014 09:21 PM
FancisMH
Feb 8, 2012 04:32 PM
davtak
Jun 28, 2011 08:47 PM
rmon
Feb 7, 2006 11:48 PM
vmx120
Sep 12, 2005 07:10 PM
