Stock Radiator Fan
Old Apr 24, 2019 | 03:51 PM
You need to make sure that you use a relay with a flyback diode built in, or add one to your wiring. If you don't the relay opening and closing will kill the temperature switch with voltage spikes. The flyback diode prevents the voltage spike on the trigger line from the temperature switch and protects it. In case you want to know what a flyback diode is, here's the Wikipedia article on them, and here's an article explaining why they should be used in circuits with relays. There's quite a few people on the S10Forum who have run into the same problems as you describe, and using a flyback diode on the relay solves the issue.
I've been using my cheap $15 Amazon temperature switch for about 8 months now without issue.
I hadn't even considered that, good info, thank you!
I've read about it being common practice on momentary switches before, the diode keeps the switch contacts from arcing and causing a buildup of corrosion, which leads to the switch no longer working.
Old Apr 24, 2019 | 04:25 PM
El_Beautor's Avatar
Yep. Exact same principle. The diode bleeds off the potential energy stored in the coil safely preventing the voltage spike when the relay is released.
Old Apr 25, 2019 | 09:08 AM
eshaw's Avatar
Mr. Electrical I'm not. Is there a how to on this any where? I have a twin Intrepid fan setup mounted to my radiator in my project truck. Eventually I'd like to have the 0411 computer run this setup but until that happens I'd like a cheap way to run the fans without reverting to buying an aftermarket controller setup. Most of the reviews I've read on multiple sites give them less than stellar reviews.
Old Apr 25, 2019 | 01:35 PM
El_Beautor's Avatar
Check out the diagrams on this StackExchange thread. They have drawings of how to add a flyback diode to common automotive relays.
Old Apr 25, 2019 | 07:52 PM
I've had 50/50 luck with these in previous vehicles in the past... Have had some that flat out died after a couple weeks, usually the ones with the probes that go into the radiator fins are harder to actually control in my experience, and then I've had some that work flawlessly and you never even think twice about them.
Randy S. Hager
Jun 11, 2016 05:56 PM
20blazer02
Jul 29, 2015 01:20 PM
Robt77
22
May 8, 2014 04:33 PM
teddybeer21
Performance & Brainstorming
Oct 15, 2009 03:01 PM
Mistermuffins
Aug 8, 2009 08:20 PM
