Stumped engine problem 89s-10 blazer
Old 03-24-2019, 10:30 PM
LesMyer's Avatar
LesMyer will become famous soon enough
Originally Posted by Sandman98207
Checked compression again sitting between 180-185 on all 6 cylinders. Swapped ICM just to test and no joy, did timing light and is spot on. So thinking harness or ecu. Will swap them out and see how things go, in swapping ecu I need to swap the proms correct?
Correct and make sure service # on the ECM is the same.
Old 03-25-2019, 09:52 AM
Sandman98207's Avatar
Sandman98207 is on a distinguished road
Thanks Les gonna ohm out harness, and compare to spare first, May find a loose connection and want to make sure harness is good and not shorted or grounded causing ECU to fry.
captblackleg
08-17-2015 10:19 PM
Toby Hanson
09-12-2012 03:23 AM
98blazr
28
07-02-2009 01:35 PM
PHOENIX
14
06-25-2009 01:07 AM
fjdavid
08-16-2007 07:32 AM
Quick Reply: Stumped engine problem 89s-10 blazer
