Stumped engine problem 89s-10 blazer
Old Mar 24, 2019 | 10:30 PM
LesMyer's Avatar
Originally Posted by Sandman98207
Checked compression again sitting between 180-185 on all 6 cylinders. Swapped ICM just to test and no joy, did timing light and is spot on. So thinking harness or ecu. Will swap them out and see how things go, in swapping ecu I need to swap the proms correct?
Correct and make sure service # on the ECM is the same.
Old Mar 25, 2019 | 09:52 AM
Sandman98207's Avatar
Sandman98207 is on a distinguished road
Thanks Les gonna ohm out harness, and compare to spare first, May find a loose connection and want to make sure harness is good and not shorted or grounded causing ECU to fry.
captblackleg
Aug 17, 2015 10:19 PM
Toby Hanson
Sep 12, 2012 03:23 AM
98blazr
28
Jul 2, 2009 01:35 PM
PHOENIX
14
Jun 25, 2009 01:07 AM
fjdavid
Aug 16, 2007 07:32 AM
