Temp guage not getting very warm
Old Jan 27, 2008 | 01:20 PM
  #21
Default RE: Temp guage not getting very warm
TAZ, you need a new t-stat. You should be at the middle (straight up) mark on the temp gauge which should be around 200-210*F with a stock 195*F t-stat.
Old Jan 27, 2008 | 10:54 PM
  #22
drperry's Avatar
Then I probably need to change mine too... It doesn't get warm unless I'm driving it
Though, the fan spinning when it's idling and cold probably isn't helping warm up, lol.
Old Jan 28, 2008 | 08:06 AM
  #23
The fan only cools what is in the radiator. When the t-stat is closed, very little of the cold coolant from the radiator is flowing into the engine. There is a bit of heat dissipation through the heater core which is being constantly circulated with hot coolant from the engine, but very little of what is in the radiator is being used and this should not affect the warm up time of your vehicle.
I know that all of the automatic climate control vehicles when in auto mode will not run the heater fan until the engine exceeds a certain temperature which is around the 1st line on the temperature gauge in the dash (~120*F). This helps the engine warm up faster.
Old Jan 28, 2008 | 04:37 PM
  #24
gohan69's Avatar
gohan69 is an unknown quantity at this point
will a bad thermostat cause a rough idle or anyother problems?
Old Jan 29, 2008 | 09:26 PM
  #25
Hanr3's Avatar
YES!
Your puter uses engine temp to control engine/tranny performance.
Old Feb 11, 2008 | 02:11 AM
  #26
cccfabioccc's Avatar
cccfabioccc is an unknown quantity at this point
just replaced my t-stat and my 96 jimmy runs so much better faster accel. heats faster shifting seems about the same but the engine performs better.
ccross13126
Mar 8, 2012 07:32 AM
zakm0n
Jan 9, 2011 07:31 PM
Schills
Sep 16, 2010 09:15 AM
bertrenolds
Dec 19, 2008 07:45 PM
myronhntr80
Mar 6, 2008 07:58 PM
