Ticking
Old May 9, 2009 | 05:27 PM
02 jimmy's Avatar
02 jimmy is on a distinguished road
Default Ticking
Well my latest problem is I can hear ticking coming from the right rear of my engine, around my exhaust manifold and 02 sensor, i'm assuming i'm hearing an exhaust leak, probably from the manifold, what do you guys think? thanks
I'll check it out closer tomorrow morning, see if some manifold studs have broke ect
Old May 9, 2009 | 05:45 PM
I would suspect a vacuum leak, but do not rule out a broken flex plate. If you have a mechanic's stethoscope, you can pin point the location of the problem.
Old May 9, 2009 | 07:10 PM
nj4x4blaze's Avatar
I had a similar noise and it turned out to be a loose spark plug #5. I tightened it up and the ticking noise went away. I have no clue how it got loose but it did.
Old May 10, 2009 | 03:53 AM
02 jimmy's Avatar
I sure hope it's not my flex plate, and i'll definatly check my spark plugs tomorrow too.
pmezo
27
Jun 7, 2020 04:46 AM
S10Blazer
Jan 13, 2010 02:12 AM
willtoskie
Jan 10, 2010 04:56 PM
Bob E.
Mar 31, 2006 11:39 AM
low
Jun 25, 2005 04:52 AM
