Tranny just rebuilt...won't shift up
Old Apr 7, 2017 | 01:27 PM
  #31
Lyricalsalvation444's Avatar
Lyricalsalvation444 is on a distinguished road
Whst is the specific name for the clutch pack I need so I can look up prices .. also is there any other parts needed that have to be replaced due to taking it apart to replace the 3/4 clutch pack? Thanks
Originally Posted by Lyricalsalvation444
Ok.. not the need I was hoping for but at least I have an answer now... so the 3-4 clutch pack is located inside the transmission correct?
Old Apr 7, 2017 | 02:39 PM
  #32
newguy's Avatar
Tranny to transfer case gasket
Old Apr 7, 2017 | 05:26 PM
  #33
What about the name for the 3-4 clutch when I go to the parts store? What's it called to where I can look It up.?
Old Apr 16, 2017 | 10:59 AM
  #34
Anythimg else you would change or replace while in there doing the 3-4 and tc gasket? Also I notice a suggestion from another mechanic the other day that mentioned something about putting in a thicker 3-4 clutch pack...what's ur opinion on that?
Old Apr 16, 2017 | 11:47 AM
  #35
Transman304's Avatar
Are you going to attempt this repair yourself? There is more than just putting in some clutches and steels. You will need to replace the lip seals or molded pistons in the input drum as more than likely they have damage form traveling to far as tha clutches burnt and thinned out. 3-4 return springs need replaced,pump gasket and o ring,filter and pan gasket are parts that come to mind. Also change the seal in the transfer cas. That's just the first things that come to mind. I like to set my 3-4 clutch clearance.030-.045.
Old Apr 17, 2017 | 12:55 PM
  #36
No my cousin is a mechanic and he's gonna do it...I'm just getting all the parts together beforehand
flowdog1972
May 30, 2011 06:44 PM
nicocide
Jul 13, 2010 07:57 PM
Ugly_Monkey
Apr 20, 2009 10:40 PM
S10Blazer
Apr 5, 2008 11:38 AM
Tittlebitties
Oct 14, 2005 12:43 AM
