tranny question
Old Jan 30, 2008 | 12:36 PM
avorg's Avatar
avorg is an unknown quantity at this point
Default tranny question
I am attempting to replace the tranny filter on a 92 s10 blazer 4wd, but can't seem to get the pan down with the limited space in there. is there something else I should remove to free up some space?
Old Jan 30, 2008 | 12:46 PM
Default RE: tranny question
You'll probably have to remove the transmission cross member. Start by supporting the transfer case on a jack, relieving some of the weight from the cross member. Then unbolt it at the frame on both sides as well as at the transmission mount.
That should give you the room you need.
ski.dive
Feb 7, 2014 05:18 AM
Logan
Jan 21, 2010 09:07 PM
xtreme03
Engine & Internal
Sep 30, 2006 06:25 PM
tomsblazer
Aug 21, 2006 01:01 PM
jagblazer01
Mar 1, 2006 10:29 PM
