tranny swap
Old Dec 8, 2007 | 08:28 PM
95Blazr's Avatar
95Blazr is an unknown quantity at this point
Default tranny swap
I have a 95 Blazer and a 97 Blazer parts truck both with 4.3 litre 265 cubic & the factory tranny (not sure yet of model number of trannys). Will the 97 swap into the 95?
Old Dec 8, 2007 | 08:43 PM
Default RE: tranny swap
You will have to check the transmission cases. I think it was sometime in late '97 when GM switched to the 2 peice transmission case which had a separate bell housing. If the engine has a steel oil pan, you should be able to swap them. If it has an aluminum oil pan and a full bell housing, then it may not be possible...
Old Dec 8, 2007 | 08:48 PM
95Blazr's Avatar
Thanks, I'll check that
ski.dive
Feb 7, 2014 05:18 AM
middleman496
Aug 7, 2007 07:53 AM
oldsledman
Apr 6, 2007 05:29 PM
91 Streeter
Engine & Internal
Feb 1, 2007 10:56 AM
KA3AX
Apr 1, 2006 11:53 AM
