Trans acting weird
Old May 13, 2019 | 10:00 PM
BlazedInMyBlazer's Avatar
BlazedInMyBlazer is on a distinguished road
Default Trans acting weird
I’ve noticed that when I’m driving between 40-55mph the trans shifts between 3-4 constantly. It’s not hard or anything, in fact it’s very subtle, but it’s there. Also if I go above 65mph it throws a code 1870 for “transmission component slipping”. But it doesn’t slip. It shifts very hard from 1-2 though. I can get it to go away by clearing the code and it doesn’t come back as long as I keep it under 65mph. Bad solenoid maybe? Any suggestions?
Old May 13, 2019 | 10:08 PM
cleburne red's Avatar
Low on fluid? When mine was leaking really bad, the torque converter wouldn't stay locked up. Kept locking and unlocking at steady cruising speed.
Old May 13, 2019 | 10:12 PM
It’s got plenty of fluid. I check it every so often. But the torque converter locking and unlocking makes sense. Would that be a new torque converter or a sensor?
Old Jun 2, 2019 | 10:06 AM
gunny357's Avatar
gunny357 is on a distinguished road
Good question. My '95 is doing the same thing except no code. Full of fluid and does well otherwise. Going to try a filter and fluid chnage here next week, when I can find some time.
Old Jun 2, 2019 | 01:49 PM
Transman304's Avatar
This has been the best at addressing the symptoms you describe. Other option is valve body replacement. The bores that the valves work in wear over time and leak.
1sttimejimmyowner
May 22, 2018 01:34 PM
Chad Christopher
Oct 12, 2017 09:48 PM
Jimmy_Blazer
Mar 24, 2015 11:24 AM
Lancealot
Feb 28, 2011 12:13 PM
nineteensixtycaddy
Aug 23, 2009 02:47 PM
