trans fluid
trans fluid
My transmission seems to consistently leak fluid needing to be replenished, but it isn't leaking it on the ground so I can only assume it's going into the transfer case. This possibility was confirmed by a mechanic, does anyone know what could be done to prevend this and what the negative effects this could have on either the transmission or transfer case? Thanks!
RE: trans fluid
i apologize i missed the post just below mine. Does anyone knwo how many hours should be planned for to remove the transfer case to replace the gasket?
BrinkDiamond
03-02-2014 03:50 PM
Mjseyler
01-05-2010 12:44 PM
DaleA
01-13-2009 08:50 PM
v8vairman
04-12-2006 01:43 PM
