trans not shifting
Old Dec 30, 2020 | 04:34 PM
tconn308's Avatar
tconn308 is on a distinguished road
Default trans not shifting
Hello everyone and Happy New Year,
My 94 GMC Jimmy S15 project has been going well, until today. I was so proud that when my son came from Michigan to visit I told him to take it for a ride, he returned and said that it would not shift...
I took it out, (mind you, I just took it to the store yesterday without any issues), and sure enough, no shift from 1 to 2. (auto)
came back and found hardly and trans fluid, what an idiot I am, any way added 4 quarts, drove it in between each quart and finally it would shift some times but not all the time.
I decided to give a rest overnight and have another go in the morning...
I am hoping that I did not hurt anything but, JC I put about $1500 into it to get it nice and then this...
Any thoughts?
Thank You!
Tim
Old Dec 31, 2020 | 08:12 AM
Transman304's Avatar
Is the speedometer working? Transmission with fluid level that low will cause failure in quick order. Where is the fluid leaking?
Brad
Old Dec 31, 2020 | 08:46 AM
tconn308's Avatar
thanks for the reply! yes, the speedo works, and that's the killer, ZERO leaks,
Old Dec 31, 2020 | 09:17 AM
tconn308's Avatar
Also Transman, on your original reply there were some pics attached, were they for my viewing, they did not show up when I replied to you. thanks again!
Old Dec 31, 2020 | 09:52 AM
I didn’t attach any photos. .?? The fluid I going into the transfer case from a failed input seal. The transfer case will be over full so take precautions when you check it as fluid will fly out and cover you and surrounding area. Transfer case will need to removed and seal replacement.
Brad
Old Dec 31, 2020 | 04:42 PM
tconn308's Avatar
thank you, you are a big help! I am not giving up on the Jimmy... It rides great and is an SLT with 95% of the options available so i will persevere, I will keep you updated with the progress.
Old Jan 1, 2021 | 12:51 PM
You’re welcome, hope things get worked out for you. Keep us posted on progress.
Brad
Chevy#
Jul 20, 2015 10:44 AM
TZFBird
Mar 7, 2015 06:13 PM
EEZ
Apr 23, 2011 11:57 PM
rbcar1
Sep 7, 2010 04:46 PM
Unlimitedsp
Headers, Intake, & Exhaust
20
Jun 29, 2010 08:12 PM
