trans shifting issues
ok,as for the hard reverse,etc. test or replace the tps. if testing,it should do a clean climb from 0.5v to 5 volts.
I doubt shift kit will help,as all it does is modifies the shifts timing in order to dramatically increase the shifts firmness and durability. if its having these issues stock,a kits only going to make it worse as there is a mechanical or electrical problem.
96jimmy4x4in
10-07-2007 09:23 PM
96Ls4Dr
02-06-2007 05:28 PM
