Transfer Case still leaking
Old Oct 7, 2015 | 08:24 PM
kuntryrebel88's Avatar
kuntryrebel88 is on a distinguished road
Default Transfer Case still leaking
New to site and looking for some help diagnosing. I have an 89 chevy k5 blazer 5.7 tbi, rebuilt 700r tranny with shift kit, and a NP 241 C transfer case. Recently replaced the tcc and torque converter. The transfer case started leaking from the output shaft seal. Replaced seal, tightened cooler lines, replaced dex2 tranny fluid to manf. specs. Still leaks. No leaks from top of transfer case, no leaks from gasket, but looks like its coming from breather tube. Two questions: does tranny and transfer share fluid (connected at top), and why would breather tube leak unless its overfillled ? Thanks.
Old Oct 8, 2015 | 08:57 PM
odat's Avatar
The trans and xfer case do not share fluid - check both the fluid levels in both the trans and xfer case - my bet is, the trans will be somewhat low and xfer case is over full - if so the front input shaft seal in the xfer case is bad letting trans fluid enter and it will need to be replaced
Old Oct 25, 2015 | 06:54 PM
Thanks odat for the reply. This forum has been giving me issues seeing replies. I will take a look at it again. Thanks.
Old Oct 26, 2015 | 01:25 PM
abig84's Avatar
yeah i second odat's response, ive had a few chevys do that to me, i went to check my transfer case one day and like a qt of trans fluid came out. i was wondering where all that trans fluid was going
Old Nov 3, 2015 | 10:46 PM
After a closer look I think it is my xfer case gasket. Im going to pull and replace and see what happens!
Flyfishen
Jun 18, 2019 11:22 AM
86k5
Feb 4, 2011 02:47 PM
J.Calderon
Nov 1, 2009 06:01 PM
CamaroBlazerguy
Sep 28, 2009 07:57 PM
rustybeast
Nov 22, 2006 12:19 AM
