Transmission
Very doable for someone that has had some mechanical experience. Going to need A few tools as far as hand tools 2-3 ft extension, swivel sockets if you have the will make the job a little easier. You need a way to support and lower transmission. The plug on the neural safety switch will need to be heated at the connector.s with heat gun or lay a drop light next to it for a while to soften the sealer so you don’t break the switch. Be sure to flush cooler lines and cooler in radiator and external cooler if equipped. Torque converter has to be completely seated in pump or major damage will be done. That’s just the minimum of things to do. Good luck.
I just read something about a key won’t come out of the ignition switch and he had no forward gears, I have the same problem my get is stuck and I have no forward gears, I only have 3 if I pull the tranny fuse, could it just be the ignition switch??? Thank you
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
