Transmission Filter change?
Im changing my transmission filter for the first time and after I drop the pan and pull the filter out theres a plastic or rubber seal that needs to come out. Then the new one needs to be put back in. My question is how do I get this plastic/rubber seal out of the trans without messing anything up? Any tips tricks or special tools I will need? let me know guys thanks. Also this is a 99 s10 blazer 4x4 if that helps.
I just did this a couple of weeks ago on my 2000 Jimmy. I'm no means an expert, but my advice is to leave the old one in. As long as it still makes a good seal with the filter, that is. I tried using a screwdriver like the Haynes manual says. No luck. I then went to Advance Auto and bought a hook tool, this did not work either. By this time, the seal was ruined from all my attempts to get it out. So I ended up using a small screwdriver and a hammer, which was a very scary thing to do on something as delicate as the transmission. Those seals are in there TIGHT, at least mine was anyway. I don't see how you can get it out cleanly. If someone else thinks leaving the old seal in is bad advice, please correct me.
e: By the way, the seal is a combination of metal/rubber. If you still really want to replace the seal, I have a link to a howto where someone used a small file to get the thing out. I'm not sure I'd want to get any metal shavings in the transmission, though.
http://www.gm-trucks.com/forums/inde...article&id=392
LannyL81
Feb 27, 2012 11:58 AM
WayneMurray1
Jan 6, 2012 11:36 AM
boondoggle
Dec 15, 2010 08:36 PM
surferman08
Oct 15, 2009 10:59 AM
06, 99, blazer, change, channge, cost, dfo, filter, installer, s10, seal, tool, tramsmission, transmission, transnision
