Transmission Filter change?
Old Oct 16, 2010 | 06:52 PM
Andy_Foster's Avatar
Andy_Foster is on a distinguished road
Default Transmission Filter change?
Im changing my transmission filter for the first time and after I drop the pan and pull the filter out theres a plastic or rubber seal that needs to come out. Then the new one needs to be put back in. My question is how do I get this plastic/rubber seal out of the trans without messing anything up? Any tips tricks or special tools I will need? let me know guys thanks. Also this is a 99 s10 blazer 4x4 if that helps.
Old Oct 16, 2010 | 07:14 PM
porkfriedrice's Avatar
porkfriedrice is on a distinguished road
I just did this a couple of weeks ago on my 2000 Jimmy. I'm no means an expert, but my advice is to leave the old one in. As long as it still makes a good seal with the filter, that is. I tried using a screwdriver like the Haynes manual says. No luck. I then went to Advance Auto and bought a hook tool, this did not work either. By this time, the seal was ruined from all my attempts to get it out. So I ended up using a small screwdriver and a hammer, which was a very scary thing to do on something as delicate as the transmission. Those seals are in there TIGHT, at least mine was anyway. I don't see how you can get it out cleanly. If someone else thinks leaving the old seal in is bad advice, please correct me.
e: By the way, the seal is a combination of metal/rubber. If you still really want to replace the seal, I have a link to a howto where someone used a small file to get the thing out. I'm not sure I'd want to get any metal shavings in the transmission, though.
http://www.gm-trucks.com/forums/inde...article&id=392
Old Oct 18, 2010 | 06:22 PM
iamchevyman5's Avatar
iamchevyman5 is an unknown quantity at this point
rent a slide hammer from the auto parts store. They'll have a specific tool that the slide hammer will mate to just for this job and it will make short work of it.
Old Oct 19, 2010 | 08:38 PM
Blazer Steve's Avatar
Blazer Steve is on a distinguished road
Hi
If the seal is in good shape use it,clean it out with a paper rag, don't use a cloth rag the lint left behind is not a good thing. just lube up the new filter neck with clean fluid.
LannyL81
Feb 27, 2012 11:58 AM
WayneMurray1
Jan 6, 2012 11:36 AM
cryspen
Apr 16, 2011 01:19 PM
boondoggle
Dec 15, 2010 08:36 PM
surferman08
Oct 15, 2009 10:59 AM
