transmission fitment. 2wd or 4wd?
Old May 17, 2010 | 08:40 PM
rcravincase's Avatar
rcravincase is an unknown quantity at this point
Default transmission fitment. 2wd or 4wd?
if i simply remove the tail housing of a 4l60e from a 98 3.8 camaro, will it bolt up to my 4.3 and transfer case? i think the bellhousing is different, can that be swapped? im going to have an extra trans from my gf's car and mine is slowly going out.
Old May 17, 2010 | 09:02 PM
Not hardly. You need to swap tail shaft; something that is only accomplished by first stripping the guts out of the transmission. The tail shaft comes out through the front of the transmission.
Old May 18, 2010 | 07:03 PM
abig84's Avatar
local trans shop charged me $100 to do this. but of course they pull the "while we were in there we noticed blah blah blah"
and if your gonna go that route its almost worth it to just rebuild the whole thing and be done with it
Old May 20, 2010 | 07:29 PM
ok, i just wanted to make sure before i picked up a $1 trans
blazen_red_4x4
Feb 3, 2015 08:06 AM
BLAZER97LS
Dec 5, 2011 02:25 PM
drperry
Tires and Wheels
Jan 28, 2007 05:40 PM
jagblazer01
Tires and Wheels
Nov 24, 2006 01:31 AM
2dr5spdblazer
Oct 3, 2006 10:41 AM
