Transmission Help
Since you are going carb you could probably go either TH350 or 700r4. Running the TH350 will probably require relocating or modifying the crossmember mount. Running the 700r4 would mean you will need to pick a non-lockup converter or else the converter lockup kit which is used with a carb engine. This comes in two styles one which just uses a toggle switch and is operator controlled, but the other is installed in the vavle body and will lock the converter automaticlly. The Th350 uses vacuum as a shift refrence and the 700R4 uses a TV cable as a link between throttle position and shifting.
GloryImSaved
07-17-2009 09:05 PM
sfesenko
12-12-2008 10:03 AM
goken50
02-13-2006 04:35 PM
