Transmission lagging, swapped from tahoe
Old Jul 22, 2015 | 12:51 AM
arnolopolis's Avatar
arnolopolis is on a distinguished road
Default Transmission lagging, swapped from tahoe
I have a 98 blazer. I had problems with the transmission slipping so I swapped it out and now it has a tranny that belonged to a 95 Tahoe. Now the truck revs high before actually moving. Before it used to take off easily and even burned out by lightly stepping on the gas but now it's slow. Anybody know what's up?
Old Jul 22, 2015 | 01:01 AM
Rusty Nuts's Avatar
Which torque converter did you use? The 95 or the 98? Do they have the same stall speed? Low fluid could cause that as well. Welcome to the forum.
Old Jul 22, 2015 | 01:04 AM
Default Thanks man
Idk about the stall speed but I used the 95, it takes long to take off so I've been shifting manually but I hear this is bad
Old Jul 22, 2015 | 01:17 AM
Rusty Nuts's Avatar
Will it shift on it's own? The more detailed description you can give will get you more accurate answers. There are some very knowledgeable members here.
Old Jul 22, 2015 | 01:29 AM
Default Thanks man
Well it shifts on its own but it lags a lot, It revs real high before actually moving and when it does , it is very slow, I don't know much about trannys but the one I put in belonged to a v8 vortec 95 Tahoe and my blazer is a 4.3 vorTec, I heard a shift kit helps a tranny get in gear butbidk, that's why I seek advice
camino88
Feb 12, 2010 02:19 PM
JimmyBlaze
Oct 6, 2009 05:14 PM
Vahomboy
Jul 16, 2009 08:10 AM
Ridinblazer
Nov 8, 2008 04:52 PM
AutomagicLS1
Apr 24, 2008 05:19 AM
