Trany removal?
Old Feb 11, 2009 | 04:33 PM
MagnumRulzes's Avatar
MagnumRulzes is an unknown quantity at this point
Default Trany removal?
This may be a silly question but how do you remove the torque converter to flywheel bolts on a 2000 S-10 blazer with a V-6? I have not removed many transmissions in my life but there has always been a section of the bell housing that you could gain access to these bolts buy removinga cover. The bell housing on this vehicle appears to be all one piece except for a small section were the starter bolts up.
Old Feb 11, 2009 | 08:21 PM
Default RE: Trany removal?
You have to remove the starter. Patience is key as the starter can really get frustrating.
Old Feb 11, 2009 | 10:41 PM
Hanr3's Avatar
Remove starter.
Remove both of the plug on the bottom of the torque converter housing.
Look through one of the holes and use the other hole for your pry bar to lcok the flexplate from turning.
Remove the bracket attached to the bellhousing that the starter goes through.
Stick your wrench in the starter hole and unbolt.
PITA but the only way.
MagnumRulzes
Feb 19, 2009 07:28 PM
mdemers2006
Jul 26, 2007 06:41 AM
MNHawk
Jul 9, 2007 11:00 AM
mikehillis1@yahoo.co
Engine & Internal
Dec 19, 2006 12:45 AM
codereddanger84
Dec 11, 2006 11:50 AM
