trouble with my '00
Old Feb 8, 2009 | 07:57 PM
firemanbob's Avatar
firemanbob is an unknown quantity at this point
Default trouble with my '00
Hey everyone i have recently bought a 2000 s-10 blazer. was doing great then out of no where it started leaking coolant. it wasnt leaking that bad but im still not happy. i can smell anti-freeze. well today i was practicing parking and all the same thing; smell and going low in the reservoir but now there is nothing on the ground. im a little troubled. OO and the last few days when i give it gas it sounds like fluid running around, like a gurgling noise. seeing that this is my first truck, i dont no much so any help would b nice.[8D]
Thanks
Josh
Old Feb 8, 2009 | 08:30 PM
Hanr3's Avatar
Default RE: trouble with my '00
Fist off welcome to the site. [sm=groupwave.gif]
The gurggling noise is in the dash and due to low anti-freeze. If you let that go the air will cuase the dexcool to solidify and plug up the heater core. You need to fix the leak in the cooling system. Finding it can be a chore.
couple thoughts.
Fill it up, and park like normal, put a piece of cardboard under the engine and see where the coolant shows up. That will help pinpoint the problem, somewhat. Water follows the path of least resistance.
You have to fill the system and get the truck up to operating temp. Pop the hood with the engine running and see if oyu can see the wet spots. Use a flashlight. Look at each hose connection, the radiator (front, back, top, and bottom) look on the block next to the powersteering pump (intake manifold and block connection), tunr the engine off and fell around the back side of the intake manifold. Find the wep hole on the water pump and check it too.
The common (as common as anything vehicle related gets) is a leaky hose connection, rad, or the intake manifold is leaking. No biggy if you have some mechanical skills and there are tons of info on the repair on this forum. The worst case could be a head gasket or cracked blaock/head. Teh clue hear would be white smoke out hte tailpipe. It would be very obvious, you would see a huge white cloud for a minute or two and then nothing, your temp gage will spike cause there is no coolant.
It is best to put your vehicle info below. you'll see what I mean after this text.
Old Feb 8, 2009 | 08:32 PM
Hanr3's Avatar
ORIGINAL: Hanr3
couple thoughts.
You have to fill the system and get the truck up to operating temp. Pop the hood with the engine running and see if oyu can see the wet spots. Use a flashlight. Look at each hose connection, the radiator (front, back, top, and bottom) look on the block next to the powersteering pump (intake manifold and block connection), tunr the engine off and fell around the back side of the intake manifold. Plus find the weep hole int he water pump, feel the top of the water pump too. Yur looking for any moisture.
dunontme
Jan 21, 2010 07:36 PM
fivemillerz
Jul 17, 2006 08:26 PM
luvfroses
Jul 7, 2005 11:44 PM
sully
Jun 8, 2005 08:06 AM
01xtreme
Headers, Intake, & Exhaust
Oct 5, 2004 02:17 AM
