Two engines in one blazer
Old May 8, 2007 | 01:00 PM
Hanr3's Avatar
Default RE: Two engines in one blazer
Not worth the hassle unless this is going to be a show truck.
If you want more power go V8. If you want insane power go big block V8.
Old May 9, 2007 | 09:57 PM
greenblazer's Avatar
greenblazer is an unknown quantity at this point
Well, I am starting to put together some prelim ideas, maybe instead of removing the rear drive shaft it might be easier to put some sort of clutch flywheel on the axle and then run a belt off the rear engine to supplement the power of the front motor. It donned on me that if there is any difference in torque/ power between the two engines then the drive shaft system is whats going to be the weak link. So some sort of clutch is going to be required so that the motors dont fight with each other.
Old May 10, 2007 | 09:24 PM
Hanr3's Avatar
Since your still thnking of doing this. Check out the Tractor/Truck pulls. they run two and more engines at a time.
Chic_Bowdrie
Mar 11, 2015 10:46 AM
Chevy33
Feb 20, 2012 12:21 PM
keatingiv
Nov 8, 2010 10:16 AM
The_Beast
Mar 27, 2010 06:32 PM
