Two things Ive noticed, What are they?
Old May 1, 2008 | 10:18 PM
cpm0487's Avatar
cpm0487 is an unknown quantity at this point
Default RE: Two things Ive noticed, What are they?
Throttle Position Sensor.
Old May 1, 2008 | 11:58 PM
djdrew010's Avatar
djdrew010 is an unknown quantity at this point
my truck does the same "roar" but it is only first thing in the morning when i get into it. it only lasts for first gear then its fine for the rest of the day.
Old May 2, 2008 | 06:17 AM
The roar may be the fan clutch on its way out. It is not supposed to engage at cold temps. You could check this by popping you hood and trying to turn the fan. If it doesn't turn very freely, then the clutch is partially engaged. This could affect your mileage.
Old May 2, 2008 | 06:35 PM
gscrippler's Avatar
gscrippler is an unknown quantity at this point
The fan will make that roar noise usually when it's running hot, with the a/c on
Old May 2, 2008 | 08:59 PM
As it should. Heat causes the clutch to engage. On a cold motor, you should be able to spin the fan with relative ease (a few rotations if spun by hand). If you can't, you mostlikely have a failed or failing clutch (i.e. partially or fully engaged all of the time).
LesMyer
Dec 4, 2014 05:16 PM
chris015
Mar 11, 2012 01:01 PM
travisrussell88
Oct 20, 2011 10:16 PM
BlazinClinton
Mar 11, 2011 08:25 AM
dougg01
Dec 10, 2010 11:47 AM
