Vacuum Switch
Vacuum Switch
Seems to be some interest in knowing what the vacuum switch looks like and where to find it. Hopefully the attached pics and description of location will help you all out.
The vacuum switch is located between the front driveshaft and the transmission on top of the t-case. You will see three vacuum hoses connected to it.
the below picture shows two vacuum switches. The top one is bad and the bottom one is good. Notice the ball on the right side of the good one? That's the switch.
[IMG]local://upfiles/679/C260EFE25A4C499A8879FA5D09467602.jpg[/IMG]
RE: Vacuum Switch
This picture shows the three vacuum hose ports and the keyway.
Any questions?
[IMG]local://upfiles/679/8A4EFE3E5B6C41579343B67E438E19E7.jpg[/IMG]
Any questions?
RE: Vacuum Switch
small little suckers...
Nice post though. Hopefully I wont need it anytime soon
RE: Vacuum Switch
could you explain the symptoms of a failed vacuumswitch?
thank you
thank you
RE: Vacuum Switch
4x4 no worky.
In other words your front axle doesn't engage even though the front driveshaft is engaged. It could also be your vacuum modulator (part that pulls the cable that locks the front differential.
cjb2145
18
10-06-2018 04:46 PM
ZAKSKY
12-09-2009 10:35 AM
fred96
06-08-2007 11:23 AM
fred96
04-07-2007 03:55 AM
