Vibrating part on engine
Old Feb 13, 2016 | 12:04 PM
silverhawk184's Avatar
silverhawk184 is on a distinguished road
Default Vibrating part on engine
Hello,
I have a 2000 Bravada that is making a noise. I have narrowed it down to this part, which I cannot identify. It is loosely attached to a rubber lined hole on the engine and rattles when I shake it. It is attached to a rigid tubing that goes under the throttle body. My guess is that it is a kind of check valve for the vacuum system.
See attached images.
Thank you,
Nick
Attached Thumbnails Vibrating part on engine-20160213_123708.jpg   Vibrating part on engine-20160213_123719.jpg   Vibrating part on engine-20160213_123741.jpg   Vibrating part on engine-20160213_123813.jpg   Vibrating part on engine-20160213_123855.jpg
Old Feb 13, 2016 | 12:29 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
This is your PCV valve. Positive crankcase ventilation system...
Old Feb 13, 2016 | 12:32 PM
odat's Avatar
PVC valve = positive crankcase ventilation valve - edit I need to type faster lol
Old Feb 13, 2016 | 12:35 PM
Thank you. Are they supposed to rattle? AKA needs to be replaced?
Old Feb 13, 2016 | 01:39 PM
CWBDDSPC's Avatar
Yes it is supposed to rattle when you shake it. Depending on the amount of vacuum at the time, it may or may not rattle when the vehicle is running.
spider21
Nov 17, 2011 06:27 PM
BBurton321
May 4, 2011 11:23 PM
Syres1
Oct 12, 2008 02:13 PM
elementalnature
Jul 9, 2008 06:47 PM
Dturner14
Jun 30, 2007 11:32 PM
