water in oil, misfire
Old Jan 1, 2010 | 05:24 PM
raycer98's Avatar
raycer98 is on a distinguished road
Default water in oil, misfire
Any help would be great. Wife called and her 2001 4.3 was running very bad. Scanned it, found multiple misfire. Also, lots of water in the oil. Checked compression. They look ok, so, I replaced the intake gaskets. Out it all together and it still runs terrible. Sometimes won't start at all. Havent driven it but let it run till thermostat opened and no oil in water yet. Why the misfire still? Friend thinks the water ruined my lifters and now they aren't opening the valves correctly. Should I replace them? Help!!
Old Jan 1, 2010 | 05:48 PM
tazz9690's Avatar
tazz9690 is on a distinguished road
have you tried a tune up after replacing the gaskets? or at least replacing the plugs?
Old Jan 2, 2010 | 11:07 AM
raycer98's Avatar
not yet. That is today. However, the cap, rotor, plugs and wires are all less than 3 months old. Seems odd to me that they would go that bad that fast. Anythings possible with a cracked cap I guess... and a multiple misfire code....back later.
Old Jan 3, 2010 | 01:52 PM
raycer98's Avatar
Well got it all fixed. New cap, rotor, plugs, and fuel filter. Filter was pretty bad, and I found one plug (#3 behind steeer column) cracked. Runs much better now. Still no water in the oil, must have been the intake gasket.
rrk03300
Nov 15, 2012 10:29 PM
cwbristow
Dec 6, 2010 02:08 PM
wolfcalibur
Sep 24, 2010 02:07 AM
kdc88
Sep 8, 2009 06:55 AM
todaresqSL2
Nov 10, 2008 01:47 PM
