What are the differences in 4.3's engines??
Old Jun 20, 2009 | 09:32 AM
bravadaAWD's Avatar
bravadaAWD is on a distinguished road
Default What are the differences in 4.3's engines??
i have a 1998 olds bravada and i blew a head gasket so i bought a new motor for it. it came out of a 2003 silveraldo with 30k miles for 500 bucks. a great deal. i swapped out the oil pan, intake, manifolds, crank sensor (in the back behind the distributor i think that is what it is) and the oil pump. somebody told me "that engine will not bolt up to your trans" i don't believe him but i would like a second opinion. thanks!
Attached Thumbnails What are the differences in 4.3's engines??-l_960365353c322cd9335bfe3d2e8b4923.jpg   What are the differences in 4.3's engines??-l_bcb563ee7d30230d9341a067b6da6d81.jpg
Old Jun 20, 2009 | 12:05 PM
You should have no problems bolting it up to your transmission.
Old Jun 21, 2009 | 03:42 AM
PHATSPEED7x's Avatar
PHATSPEED7x is on a distinguished road
1996+ Vortec are the same. You should be good.
Old Jun 21, 2009 | 12:14 PM
bravadaAWD's Avatar
yeah i thought that guy didn't know what he was talking about. i did notice that the intake was different and manifolds but i'm using my old stuff so i think it would be the same. he meantion something about 300mm?? i heard of L35? what about transmissions mine's awd but i figured i could use one out of something newer with less miles maybe even a 2wd trans? mine has 160k on it so im not sure how long it will last?
Old Jun 21, 2009 | 06:13 PM
I'd just stick with your transmission until you have reason to replace it.
You may have to swap the flex plate as I do seem to recall a difference in torque converters, but that would only be a difference in how large the torque converter was which may impact the bolting to the flex plate.
Mr Blazer LT
Jan 6, 2008 04:07 PM
96Jimmy2dr
Aug 25, 2007 09:48 PM
greenblazer
May 10, 2007 09:24 PM
sysmex
Engine & Internal
Oct 31, 2006 03:30 PM
kissmike
Feb 24, 2006 04:32 PM
