Where to set distributor
Old Apr 16, 2011 | 04:04 PM
If you have the EDI distributor setup (horizontal wire terminals), then I believe so.
Old Apr 23, 2011 | 01:02 PM
myprixxx's Avatar
myprixxx is on a distinguished road
Ok, so I have spent every other weekend for the llast3 months pulling and halfway rebuilding my motor. It got a valve job, all new gaskets, timing chain, plugs, wires. Got it all put back together and it wont run right. It starts, and will stay running if I hold the pedal a tad, but when I release it dies. The motor sounds like its missing, but not a steady or constant miss like it would for a plug. I have checked vacuum lines as well as I could, is there anything else to check? Also, I know that I need a crank relearn performed from me moving the crank around, could that cause this? Im about to give up, and wont be back in town for a few weeks
Also, there is no SES light, gas is a few months old, etc, but I dont think that would do this
Also, not sure if a bad knock sensor would be able to do any of this, but I don't think the knock sensor is in the best shape
Last edited by rriddle3; Apr 23, 2011 at 06:25 PM. Reason: COMBINING CONSECUTIVE POSTS
Old Apr 23, 2011 | 06:29 PM
rriddle3's Avatar
*Combined your two threads so everybody can see what has been done.*
Old Apr 24, 2011 | 09:27 PM
CRDuncan's Avatar
CRDuncan is on a distinguished road
Paid $43 for a relearn procedure. No help at all. The local garage tech says he thinks I am out of time. I will recheck everything but I doubt it. In the attached timing instructions there is a footnote talking about the dimple, any ideal what they are calling a dimple?
Old Apr 25, 2011 | 02:28 PM
myprixxx's Avatar
Thats what I'm scared of. It ran a hundred times better before I took it apart with no compression on the cylinder 1 and a huge leak in the intake maifold gasket. To be honest, it seems like a vacuum leak somewhere, I just cant track it down. Does anyone know if I can scan for vacuum? I have a tuner that I use to change parameters in my car, and it will pull DTCs just fine in the blazer. So im assuming it will scan all available parameters for the blazer as well, I just didnt know if there was available vacuum information.
Old Apr 25, 2011 | 02:29 PM
myprixxx's Avatar
also, as far as the dimple goes, my distributor had a small dimple in the metal down at the bottom that I saw
Old Apr 28, 2011 | 05:12 PM
myprixxx's Avatar
anyone have any ideas?
Buck731
Jul 27, 2012 01:19 PM
02 Vortech
Nitrous, Super Chargers, & Turbos
May 8, 2006 07:20 PM
02 Vortech
Mar 16, 2006 12:28 PM
blazernate1002
Mar 14, 2006 05:00 PM
black19
Suspension Tech
Feb 11, 2006 01:45 AM
