Who knows about transmissions?
Old Feb 25, 2012 | 08:23 PM
Greghshepherd@yahoo.com's Avatar
Greghshepherd@yahoo.com is on a distinguished road
Default Who knows about transmissions?
Hello,
Changed my trans fluid the other day, and now it doesnt shift right.
Reverse feels a lil sluggish, enough that I noticed, and it will not pull out in Drive. Have to shift to 1 to pull back in driveway.
The only thing I can figure is a lil 1 x 1 square electronic thing dropped down while pan was dropped. Was dangling by a wire. I think I brushed it with my knuckle. IT WAS BARELY TOUCHED.. and I snapped it back in place.
Thinking it is a solenoid but know little about a trans.
I can NOT afford to take it in a shop unless its the only solution.
Any ideas??
2000 Blazer
4 Door
4WD
Old Feb 26, 2012 | 10:06 PM
onebadsuv's Avatar
onebadsuv is on a distinguished road
Originally Posted by Greghshepherd@yahoo.com
Hello,
2000 Blazer
4 Door
4WD
Where at exactly was this dangler located ? Maybe You lost a check ball if a shift solenoid has one behind it ...
Old Feb 27, 2012 | 10:15 PM
Got it,,it was a shift solenoid.. and was dangling cuz the plastic part that pushes into the.. whatever it is.. broke off.
Thanks for the post onebadsuv...
Now I have to figure out why I suddenly have no dash or tail lights and why headlights are so dim. Oh, and that buzzing sound in the driver side dash. All started today. Man O man, every time I turn around there is an electrical issue..
Old Feb 28, 2012 | 04:05 PM
onebadsuv's Avatar
No problem , glad to help ... the plastic broke off where it plugs into the valve body - they get brittle with time . You can often get a good used replacement from a transmission shop for next to nothing .
Check Your headlight/parking light switch and connections for the lighting issues - mine didn't "buzz" but had the same no light symptoms before I replaced it with a clean JY switch and dimmer assembly ... the contacts in these switches carry current and burn out over time and use ... I've heard relays buzz like You describe too .
gojorg
May 27, 2012 09:10 PM
bking004
Aug 3, 2011 02:09 PM
blazerJim1701
Jan 28, 2011 07:21 AM
old skool luvr
Apr 13, 2010 09:05 AM
celaeno
Sep 13, 2007 09:56 PM
