will front diff from a 96 fit a 99 w/ autotrac?
My 99 has a cracked front diff case where it mounts to the frame , will a diff from a 96 fit my 99?
RE: will front diff from a 96 fit a 99 w/ autotrac?
Negative ghostrider.
In 97 GM switched from flanged diff/CV connection to a slip in style. So you need a 97+ front diff if you wanna keep your CVs. If you can get your hands on the 96 front diff and CVs (and probably the rest of the front axle?) it might be do-able. Probably easier to find a newer diff though?
JACQUART21
02-03-2011 06:59 AM
electrospark
06-14-2009 01:21 PM
