wont start at all
Old Dec 10, 2008 | 08:27 AM
DR.blazer's Avatar
DR.blazer is an unknown quantity at this point
Default RE: wont start at all
ive seen this a few times sounds like a timming issue. it could be low cylinder compression,valve clearences not adjusted properly, dirty/ clogged fuel injectors,wet or damaged ignition componets, worn or incorrect spark plug gaps. not exactly sure, this problem can sometimes be a pain in the @%$! to diagnose. are you certain the starter is cranking the engine over. if not check the to see if the starter pinoin is sticking or if the starter flywheel/ driveplate is missing anyteeth.
GOOD LUCK
Old Dec 10, 2008 | 02:11 PM
ptg327's Avatar
ptg327 is an unknown quantity at this point
o2 sensor?
Old Dec 10, 2008 | 03:36 PM
chevcamls1's Avatar
chevcamls1 is an unknown quantity at this point
the starter is fine it cranks but it just wont turn on the ecu is not givin me any codes im a replace the tps just in case i have a spare at home
Old Dec 29, 2008 | 08:05 AM
litchy.21's Avatar
litchy.21 is an unknown quantity at this point
Have you figured out the problem yet because i still havent?
Old Dec 29, 2008 | 09:51 AM
chevcamls1's Avatar
nothing yet
Old Dec 29, 2008 | 12:16 PM
Your latest description:
ORIGINAL: chevcamls1
hey my 96 blazer wont start at all i smell gas its got good spark but it never starts up, the only thing i noticed is that when i crank it wont start but when i let go of the key an put it on the off position like to remove the key it sparks again anybody has an idea??? i replaced the coil, icm, crankshaft sensor and camshaft and i scanned the ecm and no codes... any ideas??????
Makes it sound like the ignition switch in the column is the culprit. This can cause all sorts of weird things to happen.
Old Jan 1, 2009 | 10:20 AM
chevcamls1's Avatar
yessssssss lol my problem was there was too much gap between rotor and cap electrode.... problem fixed ready to sell my truck now lol
Old Jan 1, 2009 | 08:53 PM
litchy.21's Avatar
nice thanks well ill have to try that next
miller.sarah
Dec 2, 2014 12:56 PM
JimmyBlaze541
May 2, 2013 10:00 AM
Antne
May 10, 2012 06:51 PM
xXplosiive
17
Dec 3, 2009 09:32 PM
dmc919
Dec 30, 2007 10:14 PM
