1990 K5 Headlights (not high beams)
Old May 14, 2010 | 09:14 PM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
Default 1990 K5 Headlights (not high beams)
My 1990 K5's headlights do not work, so I bought new ones off of LMCTruck and the headlight electrical connections are 2 pronged, while the headlights have 4 prongs. I was looking on autozone.com and I am wondering if these headlights:
http://www.autozone.com/autozone/cat...&parentId=43-0 will fit on my truck.
Thanks,
Nick
Old May 15, 2010 | 07:17 AM
The headlights shown in the link are for the 4 headlight setup which your truck likely has. These are separate high and low beam bulbs on each side. I am not sure what you ordered from LMC, but if it has 4 connections on the back, it is not the proper part for your truck.
Old May 15, 2010 | 08:56 AM
Ck1500's Avatar
Ck1500 is on a distinguished road
yup swartlkk is right... should be only 2 prongs on it... unless you purchased some upgraded lights from LMC? not sure what you picked up...
whats the part number of the lights you bought from LMC? just curious and thought i would try and look it up and see what i find..
Ck1500
Old May 15, 2010 | 12:53 PM
swartlkk, My truck does have the 4 light setup, 2 low beams, 2 high beams.
Ck1500, the part number for the headlights is 36-0306
I will go to AutoZone today and take a look at the headlights I mentioned above.
I installed the headlight and they all work now. I got a Sylvania Xtra Vision, works good.
Last edited by swartlkk; May 15, 2010 at 07:08 PM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
Old May 16, 2010 | 05:14 PM
Ck1500's Avatar
i think those require the heavy duty headlight harness... part number 36-3581 at 29.95$.. seeing in the description it mentions if your adding high power halogen lights its required.. i was thinking about upgrading mine to this model also... but its a little down the road still...
glad to hear you go some lights working, but i am sure you would like to get the new LMC high output halogens working also...
Ck1500
ajd04zr2
Dec 14, 2014 10:05 AM
Shawn McCoy
Feb 10, 2013 01:46 AM
1998LT
Apr 1, 2011 01:07 PM
portcqb
Oct 5, 2008 07:22 PM
